plumber's foam
Old Jun 22, 2006 | 01:39 AM
jumpman83's Avatar
jumpman83
Default plumber's foam
Someone told me that plumber's foam can be sprayed into the ribbing of the trunk, back sides of panels, inside weather stripping, and under carpet and so forth, and it will do just as well as dynamat. Opinions? BTW, this is what I'm talking about:
http://www.qcsupply.com/Products/243...Dap+Quick+Foam
Old Jun 22, 2006 | 06:50 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
If you can be careful with it, it can good for SMALL parts on interior panels that may be hitting against metal. It takes time, you have to spray it and let it expand then sand it down so the panel will fit again. It's not the easiest way of doing things. I wouldn't reccomend it for large projects.
Old Jun 22, 2006 | 08:35 AM
mishqua's Avatar
mishqua
he's dead on, When the foam expands it can crack a weld.
Old Jun 22, 2006 | 06:46 PM
totalimmortal
MalleusMaleficarum
That stuff has some force behind it for just being foam.
Old Jun 22, 2006 | 08:16 PM
jumpman83's Avatar
jumpman83
Woah... damn... Guess I'm not doing that. I'm just trying to think of alternatives to dynamat that could be cheaper. I know, if you're going to do it, do it right, but I'm poor. So on that note, what about putting fiberfill behind any panel that has room behind it, or housing insulation or something like that? Just going to make the car incredibly hot or could it actually do something?
Old Jun 23, 2006 | 10:10 AM
mishqua's Avatar
mishqua
Do a search here there are alot of options. Last couple of days there were a bunch of alternitves to dynamat there web sites were posted.
