what size wire...........
Old May 21, 2006 | 01:25 PM
burnrubber's Avatar
burnrubber
Nucking Futs
Default what size wire...........
would I need to correctly hook up a 360W max 200W RMS amp? I think I have either 8g or 10g
Old May 21, 2006 | 01:30 PM
b00gers's Avatar
b00gers
8g is fine. But think about if you are ever going to plan to add another amp.
Old May 21, 2006 | 01:32 PM
burnrubber's Avatar
burnrubber
Nucking Futs
I might add another, probably the same amp, so if I do should I up the wire to 4g and daisy chain?
Old May 21, 2006 | 07:12 PM
b00gers's Avatar
b00gers
With 4g...you have a lot of headroom. It will not hurt anything but your wallet. If you are going with 8g and decide to upgrade later, you might have to add another lay of wire to provide enough power. Thatll take more time and money. Do it right the first time.
4g. :hs:
Old May 22, 2006 | 04:48 PM
mishqua's Avatar
mishqua
boogers right go with a least 4awg. Or you could do what I did and get a rope (2awg) youll never exceed power rating on that unless ya gat all crazy with you system.
Old May 24, 2006 | 04:48 PM
stratguitarist's Avatar
stratguitarist
Missing my honda...
hehehe 2awg=walmart wire kit. 0g/1awg is the big stuff.
this would be my reccomendation to you if you plan on adding. you should run the 4g wire back with a distribution block. from the d block run 8g out to your amp and when you upgrade just run another 8g wire to that one (d block should have 2 8g outputs). also run your 4 channel rcas along with your 2 channel ones at the same time that way it is done. DO NOT run your rcas down the same side as the power because it will cause crosstalk.
Old May 29, 2006 | 09:02 AM
tommyhcky13's Avatar
tommyhcky13
no you will most likely never oct gauge wire unless you are running like 2000+ watts 4ga is ideal even if you want to upgrade and the price isnt that bad
Old May 30, 2006 | 03:26 PM
mishqua's Avatar
mishqua
lol I don't think you can get phoenix gold wire @ wally world. further more 0awg is to much, why don't u run a bridge cable to it, oops thats right it not plyable.
