anyone know anything about subs n amps?
Old May 17, 2006 | 05:37 PM
splinter00's Avatar
splinter00
Default anyone know anything about subs n amps?
ok if you got some experience or anything with subs and amps pm me i need help connecting my sub to amp and i need to find some info on them but i dont no where to look,ill let you know what i need help with, so if you wanna help me just give me a shout.
Old May 17, 2006 | 06:35 PM
ewood87's Avatar
ewood87
Eric Wood
take it to someone else and have them do it.. best buy or car toys.
Old May 17, 2006 | 06:42 PM
Misa's Avatar
Misa
Pic Whore
what sub and amp do you have?
Old May 17, 2006 | 07:24 PM
b00gers's Avatar
b00gers
By posting your questions directly here you can educate others while getting advice from more than one person. Win, win.
What are you questions?
Old May 18, 2006 | 10:25 AM
splinter00's Avatar
splinter00
Ok ill just give you guys an idea of what i got here and see if you can peice it all together..
Sub: Kicker Solobaric S10L5:
Speaker Type: Passive
Nominal (RMS) Output Power: 450 Watt
Max Output Power: 900 Watt
Response Bandwidth: 24 - 100 Hz
Sensitivity: 86 dB
Additional Features: Dual voice coil
Amp: Planet Audio VX400D
CLASS D MonoBlock Power Amplifier
Max Power (2 Ohms) 600W X 1
RMS Power (2 Ohms) 350W X 1
RMS Power (4 Ohms) 200W X 1
Signal-to-Noise Ratio:100 db
Frequency Response: 25-250Hz
What do i all need as in an amp kit, and will these 2 work together? I got a sub box that says 2ohm output on the back, so i have to make my sub a 2ohm , but right now it is 4 ohm how would i change that? and will that work with the amp? BTW im new to audio stuff, i found a sweet site that shows pics on how to intall an amp so i think i could do that, just connecting it all together is the problem.
Old May 18, 2006 | 12:19 PM
Misa's Avatar
Misa
Pic Whore
the sub is dual 2Ω vc... so final impedance is 1Ω or 4Ω. the amp is only 200W rms at 4Ω, which may not be enough to efficiently run the sub. :dunno:
Old May 18, 2006 | 02:31 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
SEVERELY under powered...
Old May 18, 2006 | 05:14 PM
mishqua's Avatar
mishqua
Ya under powered, It wont hit right.
Old May 18, 2006 | 05:44 PM
splinter00's Avatar
splinter00
well its 2 4ohm dual voice coil so couldnt i paralell it into a 2ohm then go with the 2ohm on the amp for a 350 rms power?
Old May 18, 2006 | 07:22 PM
Misa's Avatar
Misa
Pic Whore
i looked up the model number you posted and it said 2 2Ω... but if im wrong, then you could do that.
