Power Wire Help
Old May 17, 2006 | 03:36 PM
Raun_31's Avatar
Raun_31
Default Power Wire Help
i have a 97 honda civic can sumbody me where do i run the power wire through the firewall because i have mines ran through the fender
Old May 17, 2006 | 05:32 PM
orbit77's Avatar
orbit77
to the right of the battery there's a grommet that you can go thru. best way i've found so far.
Old May 21, 2006 | 05:58 PM
Raun_31's Avatar
Raun_31
how do i get thru there
Old May 21, 2006 | 07:13 PM
b00gers's Avatar
b00gers
You can carefully poke a hole in the rubber and feed the new power wire through.
Old May 21, 2006 | 08:15 PM
Raun_31's Avatar
Raun_31
ok aint the hole like a rubber circle piece on it??????? because if so its a hard piece in that circle
Old May 21, 2006 | 09:59 PM
b00gers's Avatar
b00gers
Yea, it is a hole in the firewall. The hole is covered by a rubber piece that protects the wires. You have to poke a hole in the rubber, then run your wire through there. And yes, the rubber is very tough. But keep at it.
I think I used an Xacto knife to make the hole, then fished the wire through with a metal clothes hanger piece.
Old May 22, 2006 | 04:46 PM
mishqua's Avatar
mishqua
Just get a good gromet the tightens from both sides and drill a hole thru the fire wall and screw it in. U can go thru the rubber boots that are on the firewall already however it wont be sealed any longer. a good gromet will seal air\water out of the cabin.
