Alarm LED troubles - HELP ME!!!
Old Apr 30, 2006 | 07:45 PM
dew1989's Avatar
dew1989
Default Alarm LED troubles - HELP ME!!!
I am trying to get my alarm LED output to work with the led in my car and the ones I just put in my corners. The LED corner kit I bought came with a box (relay I'm guessing), one wire goes to the battery and the other to the alarm. I tapped into my internal alarm LED and connected the wire from my corners. The problem is that the both lights constantly blink, even when the car is started. When I disconnect the corner LED it functions normally. What can I do. HELP ME AND THANKS IN ADVANCE
Old May 1, 2006 | 06:43 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
It's a sign that your not supposed to do that.
Old May 2, 2006 | 02:35 PM
dew1989's Avatar
dew1989
Screw the relay, I just connected it directly to the LED and it worked, still gives off plenty of brightness!
Old May 2, 2006 | 06:08 PM
VPUPPY's Avatar
VPUPPY
I would strongly advise you not to do this. There is not enough current to safely power anything beyond the supplied LED.
Old May 2, 2006 | 07:32 PM
totalimmortal
MalleusMaleficarum
^^^Thank you!
