battery saftey..
Old Apr 10, 2006 | 11:05 AM
Default battery saftey..
edit: safety h:
can anyone go over the correct steps that should be followed to disconnect the battery, connect a power wire and then connect an amp? i just never know the correct way to do it.
Old Apr 10, 2006 | 05:50 PM
b00gers's Avatar
b00gers
Disconnect the ground on the battery.
Connect the fused power wire to the battery.
Connect the ground wire to the amp.
Connect the ground on the battery.
Old Apr 10, 2006 | 10:03 PM
Misa's Avatar
Misa
Pic Whore
:werd:
battery ground is the 1st to go, and last to be put back on
Old Apr 11, 2006 | 09:25 AM
connect the power wire from the battery to the amp before the ground to the amp? then the amp ground, then the battery ground?
Old Apr 11, 2006 | 01:23 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
You might want to check out pro install. Just a thought.
Old Apr 11, 2006 | 01:57 PM
Misa's Avatar
Misa
Pic Whore
sounds right
Old Apr 15, 2006 | 08:33 AM
First-Bass's Avatar
First-Bass
12 Volt Master
I always connect the ground to the amp then the fused, ( fuse removed from holder) power wire to the amp then reconnect the ground to the battery and dbl check all the connections at the amp, then i place the fuse back in the holder, Kinda habit, and its my way but it works and i have necer accidently popped an amp during installation or removele (sp)
Old Apr 19, 2006 | 04:26 PM
mishqua's Avatar
mishqua
lol make sure u don't have a cap hooked up and charged on the other end of your pos wire It really hurts if ya do and u put it on the frame.
