Custom Setup (pics... sort of) Ideas appreciated
Old Mar 2, 2006 | 06:13 AM
Nors's Avatar
Nors
倍力恋
Default Custom Setup (pics... sort of) Ideas appreciated
Ok so I am designed a new set up for my 1995 V6 Accord. Let me know what you think.
Pictures are attahced.
I plan on having a 15" in a ported box facing the cabin. I will be building a wall seperating the sub area from the rest of the trunk. The cap will be mounted on the amp rack facing away from the sub. I plan on putting a plexi window in the center armrest so you can see the voltmeter (on the cap) and the amps light up ect. I was wondering if this has ever been done before? I need to buy materials to build the rack/cap mount/wall to seal trunk from, any suggested places? I would like to use 1/2" MDF, would that hold about 60lbs, even if its 26" long and 17.5" wide?
I never built anything out of MDF before. Is it difficult?
Also, pics aren't really to scale.
Hopefully this will all be done in about 15 days so I will hopefully have completed pictures. Sorry if you can't understand the pictures, I MSpaint'd them.
File Type: jpg
Old Mar 2, 2006 | 06:57 AM
Nelson's Avatar
Nelson
Administrator
Nice diagrams.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Mar 2, 2006 | 07:20 AM
b00gers's Avatar
b00gers
Any particular reason why the back of the box is slanted? Slanted + ported = having fun in the design h:
Old Mar 2, 2006 | 07:57 AM
Nors's Avatar
Nors
倍力恋
Thats the way I bought it, its a qlogic box not custom made. I need to make all the other pieces/mounts ect.
Old Mar 2, 2006 | 02:36 PM
surfib's Avatar
surfib
From my experience, you get better bass response if you have the sub facing away from the seats. More airspace to push I guess.
Old Mar 3, 2006 | 04:32 PM
mishqua's Avatar
mishqua
First thing i'd do with that prefab box is run a good bead of silicone on the inside of every corner. Honestly you are better off just making your own box so many materials and so many ideas. Then you can make the perfect setup for your install.
As for the direction of the sub it doesn't really matter face it to the back of the trunk it will bounce the sound waves of your trunk lid and the higher frequency's will be less noticible. I have mine faceing into the cabin as well I just made sure my adjustments on my amp compensated for. Just wondering why you are building the wall behind your sub? Thats a lot of extra dead weight, or are you gonna go big and trick it?
Old Mar 3, 2006 | 04:44 PM
mishqua's Avatar
mishqua
O ya I would go big with the 3/4 MDF. 1/2 in will buckle fast. Dont build your amp rack out of the MDF unless you want to spend a lot of time braceing the snot out of it. MDF has alot of good uses they make great sub box's, frames and so fourth. Down side is MDF is very heavy more weight in your car the worse gas mileage you get.
