Amp placement and problems
Old Jan 5, 2006 | 10:34 AM
vtecaccord01's Avatar
vtecaccord01
Performance isn't $$$
Here is the amp I am running and the sub.
MOSFET 2-Channel Power Amplifier
* Max Power (2 Ohms) * 150W X 2
* RMS Power (4 Ohms) * 75W X 2
* Bridged Power (4 Ohms) * 300W X 1
* Signal-to-Noise Ratio * 105dB
* Frequency Response * 20Hz-20kHz
* Dimensions: * 8”W x 2-1/2”H x 11-1/4”L
Remote Subwoofer Level Control included
I have a 10" sub dual voice
Power Handling (Peak) 350W
Power Handling (Contin.) 225W
Freq.Response 30Hz-2.5kHz
Efficiency (1 Watt/1 Meter) 90 dB
Impedance 4 Ohm
Magnet Structure 80 Oz
Voice Coil 2-1/2”
Mounting Depth 5”
Also available in Dual 4 ohm Voice Coil models:
P210DVC
Old Jan 5, 2006 | 11:29 AM
vtecaccord01
Also I forget to say that even when I unhook the speakers from the amp, it is still in protection. The amp is bridged.
Old Jan 5, 2006 | 12:05 PM
b00gers's Avatar
b00gers
And this happens with both amps? Weird.
Time to check your RCA, power, ground, and remote wires.
Old Jan 5, 2006 | 02:15 PM
vtecaccord01
Yea that is the same thing I am thinking. I am going to get ride of the kit now and go with a 4 gauge amp kit instead.
Old Jan 5, 2006 | 03:13 PM
akeura369's Avatar
akeura369
i had this same prob and it was the in-line circuit breaker wasnt the right size for the amp and it couldnt handle the power going through it...before you go get a huge power cable look at your in-line fuse/circuit breaker and see how many amps it is....usually standard 20 or 40 amp fuses are used
Old Jan 5, 2006 | 03:16 PM
akeura369's Avatar
akeura369
Originally Posted by vtecaccord01
It is a DVC sub. When I first installed the new amp it played for about 40 mins then went into protection mode. Now anytime I put the fuse in it goes straight into protection. I have no idea what size inline fuse is in there. It came with the amp kit. The fuse hold is only a black casing so I wanted to upgrade it anyway. When I tried the second amp the sub still worked fine. The green light would blink and I would hear the sub catch a single but that is it.
does the black casing on the inline fuse open up? because if it does then the fuse is right under it and says the size on the top usually in white numbers
Old Jan 5, 2006 | 10:05 PM
b00gers's Avatar
b00gers
If the fuse cant handle the power going through it, it will pop. That is how a fuse functions.
Old Jan 6, 2006 | 04:58 AM
vtecaccord01
The fuse is fine. I am going to check the wiring of the sub also. Because I think it has been wired wrong.
