question about hooking up 2 amps
Old Dec 30, 2005 | 06:56 AM
elton_hsu's Avatar
elton_hsu
Default question about hooking up 2 amps
how should i wire the amp remote to 2 amps from the headunit (has only 1 remote output)? just make a Y cable? would it average the voltage volume and never get the amps turned on or something like that?
thanks!
Old Dec 30, 2005 | 09:23 PM
Arfboy's Avatar
Arfboy
Diamond Audio turns me on
Yes, that's all you'd have to do.
Old Dec 30, 2005 | 09:48 PM
sai402's Avatar
sai402
that or another easier way is just to get a small piece of remote wire from 1 amp and split it to the second amp. that way you dont have to run a long wire from your head unit.
Old Jan 2, 2006 | 12:51 PM
b00gers's Avatar
b00gers
That IS a Y-wire.h:
And yes, that is the best way to go if that remote wire is going to power on two units. If you are planning on wiring more...I would go with a relay instead of spliting it mulitple times.
