help...stereo install
you want to install a deck in the trunk??? as in there instead of in the dash? Basically get a wiring harness adapter kit plug it in then all the wires will be labeled and color coded off the harness i believe and will match up to your new deck. Extend wiring under the carpet from dash to trunk and match up wires Done
sorry. i should have explained it better....the car is a 98 civic 2dr trunk. I want to replace the deck that is in there...i need to know the wiring diagram and want to know how to remove the stock 6x9's...
