1998 2.3 CL - Will Apline s634 cd/mp3 changer work?
Old Sep 9, 2002 | 03:25 PM
jbrettgriffin's Avatar
jbrettgriffin
Default 1998 2.3 CL - Will Apline s634 cd/mp3 changer work?
Quick question - will the new alpine Mp3/cd changer s634 work with my in factory in - dash cd-controller / cd-deck? Is the factory on a 1998 cl ai-net compatible? I am a little worried that I will not be able to control/play mp3 cd's - and that would be the only benefit to buying it, of course!
Thanks in advance.
jbg
Old Sep 9, 2002 | 05:46 PM
kwhitelaw's Avatar
kwhitelaw
It is a toss up. You will need a few adapters to try though. Some people have done it on the newer cl's / tl's but some say it didn't work. You will need the adapter to plug into the factory deck, then the adapter to convert the ai-net plug to an m-bus plug. The changer won't plug directly into the adapter at the radio as the adapter only takes an m'bus plug.
Old Sep 9, 2002 | 08:32 PM
LjN_728's Avatar
LjN_728
I don't kno how the 98 CL's but i do know as for the 00' and up models, the CL's are BOSE system components. I don't exactly kno if they make an adapter for that but if u really want the changer, than look around for it. Why don't u just go with a fm modulated changer? Not as good but it does the trick!
Old Sep 9, 2002 | 09:07 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
The Ai-Net changer will not work with the stock CL deck. The MP3 changer needs a alpine deck with text capability. And Ai-Net is a totally different "language" than m-bus.
It is a cool idea... but it wont work out.
The CHM models work with your stock cd player, with the addition of a $30 adapter available at best buy or a similar store... usually the adapters at stereo specialty shops go for about $60.
FM modulated changers do work, but a changer connected directly to the deck gives you much better sound.... plus its really nice to be able to control the changer directly with the stock in dash player.
Old Sep 9, 2002 | 11:27 PM
LjN_728's Avatar
LjN_728
Ahhh...that's right!! I forgot about that. Good job pointing it out!!
Old Sep 10, 2002 | 07:30 PM
ungucpho79's Avatar
ungucpho79
they make a M-Bus to Ai-Net cable. Part# KCA-130B. The manual says that you might lose the folder up & down option, but it should work
Old Sep 11, 2002 | 06:11 AM
SumAccordGuy94
Older Honda Fanatic
only alpine decks understand the Ainet "language" it wont work with a factory honda/acura deck.
Old Sep 11, 2002 | 01:37 PM
ungucpho79's Avatar
ungucpho79
If the stock headunit has the cd changer port, and if it is M-Bus compatable then it should work. You'd run from the headunit, the M-Bus to Ai-net cable (#KCA-130B) , then the Ai-net cable to the changer. I took this information out of the owners manual for the changer. this makes gives any alpine headunit the ability to play mp3's. If the cl headunit has the port for the M-bus system, then when used along with the cable, it should play mp3's. You just wouldn't get all the options that come along with the changer.
Old Sep 11, 2002 | 05:49 PM
SumAccordGuy94
Older Honda Fanatic
My guy and I discussed this today, and we think it maybe worth a shot... but you wont have the ability to go over track #99... being so many MP3's can be crammed onto a CD, you wont be able to play all of them. You also wont have any naming features, no display of text and none of the other fancy options... so basically you'd have to scan each CD to know whats on it.
He didnt have the ainet adapter in stock, or else we would have tried it... its on order and we're gonna try if when it comes in, that is if someone else dosent try it first...
seal3k
Jul 17, 2005 05:18 PM
forre65413
Accord
Apr 10, 2005 08:32 PM
cesarcoral
Mar 29, 2004 04:57 PM
xbladr
4
Feb 27, 2003 01:08 PM
offthahook
Dec 24, 2002 12:07 PM
