wiring help
Old Oct 13, 2005 | 12:20 PM
foefinga's Avatar
foefinga
Default electrical help......
i just got my new deck and tried to install it but it didnt work. my cousin has an integra too and i wired it the same way no power. then i plugged my radio into his car and it worked. so im guessing the wiring in my car is messed? are there alternatives?
Old Oct 13, 2005 | 03:55 PM
2legit2quit's Avatar
2legit2quit
You Big Dummy
Did the factory radio work before you took it out?
Old Oct 19, 2005 | 11:17 PM
foefinga's Avatar
foefinga
there was no stock radio but there was a kenwood deck with no face so i dont if it was or wasnt working. also when i took it off to try my new radio i notice the clock on the dash stop working
Old Oct 21, 2005 | 05:29 AM
Integral's Avatar
Integral
Nightmare Motorsports
Check your fuses, in the engine bay fuse box there should be a fuse for "Radio", I've heard that for some brands of aftermarket cd players, that the stock fuse isnt quite strong enough for it, so if that fuse keeps blowing, you may need to put in a slightly higher fuse. If the fuse is fine, I'd say to check the radio wires for power (I believe a voltimeter can do this)
Old Oct 21, 2005 | 07:53 AM
2legit2quit
You Big Dummy
Yeah, since the clock stopped working at the same time, maybe it was the fuse.
Old Oct 27, 2005 | 02:26 AM
foefinga's Avatar
foefinga
thanks, il try the fuse in the engine but it looked good when i looked at. "I'd say to check the radio wires for power (I believe a voltimeter can do this)" I was gonna buy a voltimeter but didnt really know which one to get and dont know how to use it. haha LOL..... If the radio wire isnt getting any power, is there an another way i can wire my cd player? direct to the battery?
Old Oct 27, 2005 | 07:21 PM
Integral's Avatar
Integral
You could rewire it to where the current wire is going... or another power source. And the fuse box for radio should be in the car, under the driver side panel...
Old Oct 29, 2005 | 01:27 PM
2legit2quit
You Big Dummy
You can wire it directly to another source. The cig lighter fuse, winshield wiper fuse.....there's lots of options. Just make sure the constant power wire goes to somthing with constant power, and the switched to something that turns on when the key is turned to ACC.
Old Nov 2, 2005 | 01:50 AM
foefinga's Avatar
foefinga
"You can wire it directly to another source. The cig lighter fuse, winshield wiper fuse.....there's lots of options. Just make sure the constant power wire goes to somthing with constant power, and the switched to something that turns on when the key is turned to ACC." ok i should wire it directly to the fuse box? im lost and confused im thinking about just taking it to a shop and have them rewire my electrical system. would even it be worth it for me to do that?
Old Nov 2, 2005 | 05:52 AM
skip259's Avatar
skip259
have you even checked to see if the fuse is bad?
