over or under power
Diamond Audio turns me on
Originally Posted by totalimmortal
Incorrect my friend. Underpower a speaker will blow VC's faster than just about anything. Aside from massivly overpowering. As stated above, a little headroom is always good.
Underpowering IN AND OF ITSELF does NOT damage speakers. If they did, your speakers would be blowing everytime you turn the volume down. Underpowering only damages speakers because of USER ERROR. People tend to turn gains up to compensate for lower output, which can lead to clipped signals that OVERPOWER a speaker. Speakers only die from exceeding thermal or mechanical limits. You don't do either by underpowering a speaker.
I do agree that headroom is good and that's why I have a 400Wx2 amp feeding speakers rated to handle 150W, but that does not negate the fact that underpowering does not damage speakers (but can lead to user error which destroys speakers).
MalleusMaleficarum
Volume has NO bearing on power. Underpowering and clipping the signal through upping the gain can lead to actual mechanical failure. The surround or spider can tear. Overpowering can burn or even melt VC's. Thats why aftermarket decks blow factory speakers, thermal breakdown.
Sorry, but you're wrong again. You really don't know what you're talking about.
Volume has EVERY bearing on power. The volume control is essentially a potentiometer that determines how much power the amp feeds the speaker, thereby controlling the volume. Lowering the volume lowers the power the speakers receive. Increasing the volume increases the power the speakers receive.
Read what you typed, then read what I typed. If you're going to try and correct me, you should at least be sure that you understand what I'm saying. Again, underpowering IN AND OF ITSELF doesn't damage the speaker. It isn't the reason for the clipped signal. By your own reasoning, the source of the problem is USER ERROR. An unknowledgeable person turning the gains up to a point where the signal is clipped, leading to a condition where the speakers have excessive power/heat, is attributed to user error, not underpowering.
Aftermarket decks blow factory speakers because factory speakers have power handling somewhere in the range of 5-10W RMS.
first off the gain is not a volume knob and if it is being set too high to try and make up for too little power that is user error. technicaly speaking blowing speakers at all is user error, either through the use of overdriving the speakers with too much power or by setting the gain incorrectly which in turn creates clipped signals and distortion and therby creating excess heat
when you suggest that you invariably turn the gain up to make it louder when underpowering you suggest that it can be used as a volume.
as far as the argument goes both can blow speakers was my point but someone with an understanding of both will not blow your speakers with either. speakers have their mechanical limits and if you know what to listem for things are ok either way, just dont be goofy about it.
MalleusMaleficarum
I guess thats why I work where I work then. Because I dont know shit. They hired me for car audio because Im unqualified. I have a question, is anyone on here MECP certified??
