Disconnecting negative battery cable...
Will this trip the code on the radio or does the positive have to be disconnected to? I want to reset my CEL but don't have my radio code. Thanks.
you can get the same effect by pulling the #15 fuse called "radio" on the passenger side fuse box.
When you reset the ECU to clear codes, you have to cut power ... unfortunately this is still tied to the radio. No matter what you do, you're going to have to re-enter in that security code.
Relevance is irrelevant
Originally Posted by treetribe
Hey, I connected my amp recently to my stock HU and it didn't ask for the code. I have an '05 Sedan i4 5at.
On permanent hiatus
Pulling the ECU fuse in the under-hood fuse box will reset the ECU without cutting power to the radio. It has to be pulled much longer than the negative terminal of the battery, but it still does the job. Pull it for 10 minutes and then put it back in and see if that helps.
