proper way to carpet
Old Aug 13, 2005 | 05:15 PM
96exr's Avatar
96exr
Default proper way to carpet
hey...
i've got a sub box that i'm making, i've cut all the pieces but have not put it together.
a) should i carpet each piece and then nail/screw the box together
or
b) should i put teh box together, and then try to carpet it ( i think it will be hard)
and what do i use? contact cement or like a spray adhesive?
thanks, any links to carpeting a sub box would be helpful.
Old Aug 13, 2005 | 05:40 PM
cobbcustomz's Avatar
cobbcustomz
i would say to carpet the box after completion. and i believe most places use a spray adhesive to hold the carpet
Old Aug 13, 2005 | 06:34 PM
b00gers's Avatar
b00gers
Put the box together first. You will get a better seal between the pieces. Spray adhesive works.
Old Aug 13, 2005 | 07:14 PM
96exr's Avatar
96exr
yea...thats what i wsa thinking....but now....how the hell do i wrap it in carpet to make it look professional?
Old Aug 13, 2005 | 09:02 PM
b00gers's Avatar
b00gers
It is easy with thicker carpet since you can hide the seams, but I really think it is something where practice makes perfect. Good luck.
Old Aug 14, 2005 | 06:27 AM
96exr's Avatar
96exr
hmmm.....is there any site or anything or any techniques? do i wrap it like a present?
somebody had mentioned carpeting the sub box by cutting the carpet in triangles?
Old Aug 14, 2005 | 10:21 AM
Takoon's Avatar
Takoon
yeah, wrap it like a present in a sense. On the corners you will need to start doing that triangle thing, but only do it so that you can get the carpet to fold over flush. After you let it dry up and all, go back and caulk the edges in the inside of the box for more of a tight seal.
Good Luck man.
Old Aug 14, 2005 | 06:13 PM
96exr's Avatar
96exr
i'm scared its gonna turn out like crap
Old Aug 14, 2005 | 07:06 PM
b00gers's Avatar
b00gers
Measure thrice, cut once...or in this case, glue once also h:
Old Aug 15, 2005 | 03:39 AM
sslkickers's Avatar
sslkickers
My Car Is Slow
http://www.crutchfieldadvisor.com/IS...build_box.html
try that
