what are OHM's and RMS'?
Old Sep 4, 2002 | 04:36 PM
Default what are OHM's and RMS'?
just wondering.. i never knew what they were.. or stand for
Old Sep 4, 2002 | 04:59 PM
acuradriva's Avatar
acuradriva
ohms doesn't stand for anything. it is the measurement of the resistance an object has to current flow. like a meter is a way to measure distance. 1 ohm of resistance connected to a 1 volt power supply will have 1 Amp of current flowing threw the device.
RMS stands for root means square. It is what you should look at when you are buying amps and speakers. I believe it is .707 x peak power?
Old Sep 4, 2002 | 05:07 PM
b00gers's Avatar
b00gers
well said...^
let me put it in words i understand....
when dealing with car audio....OHM is a rating on the speakers, per voice coil. and on the amp, the amp gives out different amounts of power at different OHM. the lower the OHM, the more power it can give off. but some amps wont play at too low of an impedance (OHM) because it will cause them to run really hot.
so what you will have to do when looking at sub and amp combos, is the impedance of the sub, and the what impedance does the amp give the most power. if they match...cool
RMS.....thats the power rating of the speaker. peak doesnt mean much...RMS is a number to look at.
Old Sep 6, 2002 | 03:25 AM
INlude's Avatar
INlude
RMS (root mean square) can be calculated using the .707 x Peak Power method. its not exactly accurate but for car audio purposes its just fine.
AceMc03
May 6, 2006 07:22 PM
asheylarry
Prelude
2
Mar 3, 2006 10:45 AM
JDM_civicEG
14
Oct 25, 2004 06:28 AM
