Which sub BOX????????????
Old Jul 31, 2005 | 08:55 PM
b00gers's Avatar
b00gers
Originally Posted by lilgdog7
hi, i just bought an a8002t audiobahn 1600w amp. I will be getting 2 of the AW1251t subwoofers and was wondering which box will makw them sound the best and loudest? Regular wooden box or a bandpass box? http://cgi.ebay.com/TWO-AUDIOBAHN-AW...QQcmdZViewItem
thanks
I am not a fan of bandpass boxes. As for the type of box you should get, Audiobahn should list what type of box that sub will be good in.
Originally Posted by dspencer24
depends more on you actually what kinda of bass do you like? do you like clean tight bass or do you like loud more of a boom bass, if you went with audiobahn then you probably dont care to much for sound quality!
hehe. Not a fan of Audiobahn either :wavey:
Originally Posted by ThisizBRIAN
what do you guys think of infinity perfect 10's?
They are good subs. Nothing to :bowdown: over, but for the money, they arent too bad. For a bit over $100, you can pick up a 11kv.2 from Elemental Designs. I have it, and love it.
Originally Posted by Takoon
Don't just any box though, to get the full sound of a sub, it's better off in the long run to get a box built to the specs of the sub(s).
I say the correct enclosure is more important than the woofer. A bad box can make a $500 woofer sound like shit.
i was wondering is it ok to get some subwoofers that are more watts than the sub. for example: 1600 watt amp with 800 rms, and 2 12' subs that totals 2000 watts and 1000 rms. i jus didnt want to blow the subs and was wondering is this ok, or not?
Yes. Next time, just look at the RMS numbers. Max wattage doesnt mean a single thing. It is all marketing. In that case, each sub is rated for 500 watts RMS but only given 400 watts RMS? In cases like that, you can the possibiltiy of sending the sub a clipped signal if you arent careful. It is better to have the amp give more power than to give it less power. But either way, the user has to play it smart and know how to set the amps.
Old Jul 31, 2005 | 09:19 PM
lilgdog7's Avatar
lilgdog7
can u explain that 1 more time?
Old Jul 31, 2005 | 09:30 PM
b00gers's Avatar
b00gers
1. When looking at subs or amps, dont look at the MAX wattage numbers. Always look at the RMS numbers.
2. When you are buying an amp and sub, you want the RMS numbers to be as close as possible. But this does not always happen. So you either have an amp that will provide too much power, or an amp that provides too little power (according to the RMS).
When you have an amp that provides too much power, this is not always a bad thing if the number is reasonable...such as feeding a 350 watt sub with 400 watts or giving a 500 watt sub 600 watts. This is not going to blow the sub. Of course this is assuming that you wire the amp correctly and set the gains and any other adjustments correctly.
When you have an amp that provides too LITTLE power, this is not always such a bad thing either. A lot of people say that it will destroy the sub. It wont. It is in this situation that the user can possibly destroy the sub. When you have an amp that provides too little power, people usually want to turn up the gains and volume to make the sub louder. When you do this, the limits of the amp is getting close. If you push it any harder, then it starts clipping the signal. Then the sub goes byebye.
So I say that it is better to have an amp that provides too much power, rather than an amp that provides too little.
Old Jul 31, 2005 | 10:15 PM
Takoon's Avatar
Takoon
yeah it's okay, but you might overheat the amp causing it to blow out.
Old Aug 1, 2005 | 06:34 AM
lilgdog7's Avatar
lilgdog7
thanks
Old Aug 1, 2005 | 01:16 PM
akeura369's Avatar
akeura369
what do u mean by clipping the signal?
Old Aug 1, 2005 | 01:37 PM
b00gers's Avatar
b00gers
Basically an overload of the amp. It is when the signals coming from the amp exceeds the voltage supply it is given. So when it is overloads, the signal clips. Which is bad for the woofer.
Old Aug 1, 2005 | 02:34 PM
extensioncordy's Avatar
extensioncordy
EG6
i have 2 12's in my eg hatch and i think its pretty shitty they were there when i bought the car and theyre made custom fit in a fiberglass box so i have no backseat...and everything was sapose to be rattle proof and most everything still rattles...
bottem line...iif u want good quality sound dont go 12's for a civic...1 of them at the most
Old Aug 1, 2005 | 03:22 PM
b00gers's Avatar
b00gers
Wrong.
2 12's can sound GREAT in a small car like a Civic. Everything is in the installation. And yes, with cheap light cars like Hondas, things are going to rattle no doubt. That is what sound deadener is for.
Old Aug 1, 2005 | 04:30 PM
akeura369's Avatar
akeura369
thanks
