Help: My 1999 Accord Player swalled by CD
Old Jul 29, 2005 | 11:54 AM
dcmetro's Avatar
dcmetro
Default Help: My 1999 Accord Player swalled by CD
When I try to take the CD out, it reads CD Err. Can I get it out? Called Honda but they say that they do not touch the player and will need to send it back to manufacturer which shall cost a lot of dough to get the CD out..please help
Old Jul 30, 2005 | 06:09 AM
akeura369's Avatar
akeura369
you might be screwed but u could try and take the deck out then take a few screws out..as long as u put everything back the way it was but i dono
Old Jul 30, 2005 | 02:27 PM
Brian C's Avatar
Brian C
Can someone please explain how you take the radio out of a 98 accord EX?
Thanks
Old Aug 3, 2005 | 09:56 AM
dcmetro's Avatar
dcmetro
brian: installdr.com has excellent doc on that
Old Aug 3, 2005 | 11:25 AM
Dado's Avatar
Dado
This is what you do....The dash part that surrounds your radio temp controls and vents pops out. But there are a couple of screws holding it in place. I suggest using a magnatized philips. Pop the dash clock out and unhook that there is a screw behind it. The air conditioning knobs come off also, so remove those too....Once you have the dash faceplate off there are four screws holding in your cd player. If you have the kind that is just the cd player and the radio is atop of that then just seperate the two. Then get to work on the cd player. Rule of thumb if you factory is crewin up buy a new one.
Old Aug 4, 2005 | 12:16 AM
4drman's Avatar
4drman
Takes more than patience.
in my 92 civic you just unscrew the ash tray compartment from the front and sides and youll have a clear view of the screws holding it in place.
Old Aug 9, 2005 | 06:25 AM
dcmetro's Avatar
dcmetro
does anyone know how I can open up my current honda stock player (1999)? Have installed a new deck in place of honda deck..but CD is still stuck in Honda deck
