need some insight...
Old Jul 22, 2005 | 08:50 AM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
Default need some insight...
I just got my sub Alpine Type E
The box says its 750peak power with 250 RMS at 4ohms . Im thinking about getting this amp: Alpine MRP-M350 mono amp. This amp puts out 200RMS at 4ohms. Will it be good enough to power the sub or should i get a stronger amp?
Old Jul 22, 2005 | 09:52 AM
b00gers's Avatar
b00gers
With underpowering a sub, you risk sending a clipped signal to the sub. With only 200 watts, you probably wont be able push the sub as hard as it can be pushed. People will usually up the gain and volume to compensate and because the amp is already at its limit, it will send a clipped signal, which can mess up the sub. I would look at a stronger amp.
Old Jul 22, 2005 | 12:05 PM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
hmm then i'll have to spend a few more bucks kk ty for info
Old Jul 22, 2005 | 12:28 PM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
so correct me if im wrong... as long as the amps power at 4ohms is over 250rms then the sub wont clip? or a higher RMS would be better?
SONY XPLOD XM-D6000GTX i might consider this one here's the specs
http://www.etronics.com/product.asp?...ore=&catid=304
im trying to spend under 200 in price with shipping.
i also saw this one http://www.hookedontronics.com/show_...wood_KAC-9102D
Kenwood KAC-8152D 1-Channel Amplifier <=== this one is 300RMS @4ohms i can get for 167 free shipping no tax
Old Jul 22, 2005 | 03:46 PM
owen996's Avatar
owen996
Generally, you want to try to match the specs on the sub with the amp, so say 250 watts sub, and 250 watts amp. I run a 300 watt sub and a amp that is 400 watts at 12.2 volts, which is probably closer to 475 amps when my car is running. I turned the gains down slightly so I can turn up the volume a little more. No clipping, no distortion, and it pounds when I need it to.
In the end, that Kenwood is prolly the best thing you could buy for the money.
Old Jul 22, 2005 | 10:26 PM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
ok thank you for the insight im gonna get the 300RMS @4ohms then since it will be good for the sub and from what ive heard in addition to your opinion on kenwood i've also seen that kenwood is much better than the sony amps.
TY for the info guys im gonna order the amp tomorrow, i'll try to post pics of the sub amp combo after installation.
Old Jul 23, 2005 | 12:37 AM
owen996's Avatar
owen996
yea, definitely want to see pics, glad we could help.
Old Jul 23, 2005 | 07:24 AM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
which wiring do i need for this amp sorry if i sound like a complete fool, i just wanna be safe than sorry
Old Jul 23, 2005 | 08:10 AM
owen996's Avatar
owen996
http://www.knukonceptz.com/productDe...?prodID=eKo-K4
this will do it all right here for ya...
Old Jul 23, 2005 | 10:52 AM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
so basically i need a 4 gauge amp kit for the install?
