amp won't turn on PLEASE HELP
Old Jul 15, 2005 | 07:40 PM
sslkickers's Avatar
sslkickers
My Car Is Slow
Default amp won't turn on PLEASE HELP
just wired in my amp and it won't come on. i checked the remote turn on wire
i'm wondering a)is it my power wire b)i touched my ground to something bad or something
c)i accidentally touched it to something and saw sparks
d)the remote turn on needs electrical tape
please help
Old Jul 15, 2005 | 11:53 PM
DarkSideAccord's Avatar
DarkSideAccord
Chidori-chan :love:
did u use a stock head unit? if yes, u need an RCA convertor....same thing happening to me... good luck
Old Jul 16, 2005 | 12:00 AM
b00gers's Avatar
b00gers
Something wont turn on? First and easiest thing to check are the fuses. And once you mention sparks...I am pretty sure that is the problem.
1. Check the fuse on the power wire to the amp.
2. Check the RADIO fuse that is under the dash.
3. Check the RADIO fuse that is under the hood.
Old Jul 16, 2005 | 07:02 AM
sslkickers's Avatar
sslkickers
My Car Is Slow
the radio and everything still works but my amp for the subs won't turn on
i have the rcas and they are plugged in
i was afraid that the sparks were the problem but i hope not
its still on warranty so i think i'll send it in with that
but alright
Old Jul 16, 2005 | 07:15 AM
sslkickers's Avatar
sslkickers
My Car Is Slow
no the head unit is a jvc 50w x 4
Old Jul 16, 2005 | 07:54 AM
b00gers's Avatar
b00gers
but alright
Sorry...I dont know what went on in my head last night to suggest looking at the radio fuses :doh:
Is your remote wire hooked up correctly? You can take a small piece of wire going from the +12 power terminal of the amp to the remote terminal to test if the remote wire is the problem. An amp should turn on regardless of if the RCAs are looked up.
Old Jul 16, 2005 | 08:38 AM
sslkickers's Avatar
sslkickers
My Car Is Slow
well you were right for me to check the fuses
i went back and checked all of them and the power wire fuse was blown
i replaced it with a 30 amp one again and checked the rest but they aren't working still
i also checked my remote wire and it is still not working
two ideas i have
1)i shorted it out with the sparks i guess
2)the remote wire is somehow not connected right
a buddy of mine said i may have shorted the ground wire out so i don't know about that as a possibility
Old Jul 16, 2005 | 05:51 PM
b00gers's Avatar
b00gers
Have you tried that?
Old Jul 16, 2005 | 08:25 PM
sslkickers's Avatar
sslkickers
My Car Is Slow
no but this guy at my work suggested i fried my ground cable
could that be it?
Old Jul 16, 2005 | 09:47 PM
shitbrick2's Avatar
shitbrick2
Banned
sounds like something is shorted, fried groung cable never heard of that one.
what kind of amp?
