Mono sub amp
I am having some problems that just started with my mono sub amp. These are the problems. When I first turn on the head unit and amp, the amp doesn't always come on. The light on the amp flickers once about 20 seconds apart before it comes on. It is like it turns on for less then a second and then turns off. Second, it clips really easily and sometimes it will turn off for seemingly no reason and start the flicker process over again. It is frustrating as hell. I have checked the fuses and the wires and unless i am missing something I don't think that is the problem. I first thought it could be the ground but I am not sure.
Here is what I have. Honda civic 2002 Head unit\ alpine 9823 stock in the front alpine 6x9 in the rear Infinity mono sub 610a two infinity 1030 w in a sealed box |
Maybe you should check your ground or remote wire.
The subs are single voice coil 4 OHM. And that amp is stable down to 2 OHM, so there goes my theory. This is just start happening? Or have the setup never worked before. |
it just started happening. the remote wire, i kind of rigged. I just cut it and used electrical tape but I am sure I made a good connection. However, the alpine 9823 has a switch to turn off the sub amp but it has never worked. I tried turning it off when i first installed it and it just stayed on.
could be a faulty head unit or a very poor ground.
