High signal only when engine off??
Old May 1, 2005 | 09:22 PM
kill_kill_kill's Avatar
kill_kill_kill
it's sarcastic dude
Default High signal only when engine off??
Does anyone know of a line that would go high only when the egine is off on any honda vehilce? Sort of like what would ideally power an alarm but the amperage is not important. I know that sounds weird, it's for a custom project.
Also, this site, http://www.hondahookup.com/manuals/ seems to be down, anyone know of a similar resource, wiring diagrams and schematics and what not?
thanks in advance for any assistance
Old May 1, 2005 | 09:56 PM
ihookitup4u's Avatar
ihookitup4u
I dont exactly know of a wire that does that but if you wanna make a wire that only works with they key off then hook a relay to your ignition using the ignition for ground on the relay then when you turn the car off the relay will energize.
ignition to 85
constant power to 86 and 87
power output when ignition off to 30
nothing to 87a
the reason that works is because when the ignition is off it rests on ground.
Hope I Helped!!!!!!!
Old May 1, 2005 | 10:01 PM
b00gers's Avatar
b00gers
What diagram are you looking for? I have a service manual for a 94 Integra on pdf. PM is the key :happysad:
Old May 1, 2005 | 10:59 PM
Sh22awndo's Avatar
Sh22awndo
What exactly are you trying to do?
Old May 2, 2005 | 08:20 AM
kill_kill_kill
it's sarcastic dude
thanks for all the responses.
I'm trying to put a flashing red light (fake alarm-LM555 based circuit) that goes off only when parked, the relay to ignition sounds like the key. I'll put up on of those cool how tos if it works out.
Again thanks alot for all responses, and speficially I need the 96 honda civic wiring diagrams.
Old May 2, 2005 | 08:50 AM
Sh22awndo's Avatar
Sh22awndo
Oh,......I know what your doing now. Those hyper LED thing usually just have 3 wires, black, red, and yellow.
Red wire-constant 12 v
black wire-ground
yellow-switched 12/ ignition
Just hook it up like that and it should be fine. Ithink I e-maile you a wiring diagram too.
