infinity 6000cs help install tweets
Old Apr 29, 2005 | 03:27 PM
Chizzy's Avatar
Chizzy
Default infinity 6000cs help install tweets
I just got some 6000cs infinity's. What's the best place to mount the A. Tweeters and B. Crossovers
Old Apr 29, 2005 | 08:20 PM
ihookitup4u's Avatar
ihookitup4u
In the car. Where we would need to know what kinda car? front or rear? 4door , 2door? Something !
Old Apr 29, 2005 | 09:06 PM
Chizzy's Avatar
Chizzy
94 teg rs 2dr hatch. in the front. I have 2 x-overs about 4 x 2 inches large. Can the tweeters be mounted anywhere? there an inch big. What's the best spot to put them
Old Apr 30, 2005 | 09:40 PM
ihookitup4u
The tweeters i would mount in front of the door handle like the 1's that come stock with tweets. Great place for em they sound real good look clean ( as long as u flush mount em) and as far as the x-overs its hard to run wires through the door jamb cause the are a solid plug so the 2nd best place for em is under the pocket handle ( u use to close the door ) on the inside car side of the vapor barrier. Try to not put em in the door if your plastic barrier is a ripped up ,and puttin em in a plastic bag taped up dropped in the door is a short cut way of doing things. There is plenty of room in the bow of the door panel to hide em.
Old May 1, 2005 | 08:42 PM
Chizzy's Avatar
Chizzy
What do you mean "like the one that comes stock with tweets". Do GSR's have tweets with them? Anyways I found where you were talking about, just in front of the handle where there is plastic. What tool would I use to get a clean 1 inch hole in there? I think my dad has a drill bit that big but I think it's only for wood.
Old May 1, 2005 | 10:00 PM
b00gers's Avatar
b00gers
I would be very careful using a drill bit to cut that hole. Usually the ones for wood have really jagged teeth. That might not work well with plastic. Do you have a Dremel too?
Another place to put it is in your sail panel.
Old May 1, 2005 | 10:01 PM
ihookitup4u
A wood hole saw is fine I use 1 of em everytime i do a platic panel tweet. I normaly drill the pilot from the front but hole saw from the back side to make sure you dont tear up the front. ya know wobble, slip, catch any teeth.
