Finished boxes and crossover install
Originally Posted by DaNnYsEvEn
you forgot the dual purpose optima yellow top!
Originally Posted by ihookitup4u
no, i was saying if an amp eats up 75 amps and you only have a 65amp alternator that if you are pushing the amp to its max then the lack of feed will stress the amp and it will heat up, heat is bad cause be all know that electronics are powered by smoke and if you let the smoke out it will no longer work.
Either way any dual voice coil speaker can blow an amp if it is wired work, normally people go parallel to bridged and 1 ohm an amp to death.
Ok, just making sure. :happysad:
Originally Posted by CplJon
Man, thats awesome D7 amp, TDX, I'm jealous. Those specs are great and the audible difference is incredible. Ported is the way to go, hope yours works out good. :cheers:
I was running a pair of MacDaddys before, but the 15" TDX was just too damn sick for me to pass up. I'm such a Diamond whore.
I hear ya, the dealer I used to work with had 8 12" macdaddy's in his chevy 2500 truck. I think he changed them all to TDX's, must be nice to be sponsored, nonetheless they were some of the sweetest things I've ever heard. I always wanted those M5's, but they consistently come out with newer and upgraded products each year. I'm thinking some D6 61/2's up front for the rear fill--kind of an oxymoron.
