sub troubles
Originally Posted by KuttinEdge
Being that you only have the one subwoofer hooked up, as far as I can tell, chances are that it is not because the amp cant handle the impedance, being that is either a 2,4,or 6ohm speaker.
Tell us what impedance your sub is, and how you have it hooked up to your amplifier. Also, check ALL your connections, the ones on your cd player (usually you only need to check the ground acc and power), as well as the connection to your battery. You should be sure that you have sufficient gauge wire (if it is a true 800 wrms amplifier, then you are going to need at least 4 gauge wiring).
[QUOTE=TTT]Unless its a two ohm speaker wired to bridge the amp... most amps do not handle a 2 ohm mono load.
Actually, i really cant even think of any Mono amplifier (and being that he is running a 15 i would think he would be running a class D) that cant handle 2 ohms (or at least claim to handle anyway)....
There are a million and one things that it may be. I dont know if i would recommend switching out the amplifier with another being that you are not sure where the problem is. Though if it was a serious problem where there were wires touching (- the remote wire), fuses would have blown or your car would have caught on fire, so an amplifier may not be out of the question
are you running anything else off the amp if so and they turn off the amp is probably overheated or toast, if other speakers work then it is something in your connection or possibly the speaker itself, most likely sounds like a bad amp though, sorry
