Ways to restraign 1 12
Old Aug 15, 2002 | 07:15 PM
Matt86's Avatar
Matt86
vtec ownz j00
Default Ways to restraign 1 12
For those of you that have one sub how do you keep it from rolling around back in the trunk? When i get mine i don't want it to roll around but i also don't want to bolt it down. I want it to be pretty easy to take it out. Thanks
Old Aug 15, 2002 | 08:17 PM
nando11211's Avatar
nando11211
Well if the box is pretty heavy I guarantee you that it won't move much. But if the box is light, maybe a QLogic one for a 1 12 then you can drill two screws (don't drill them in all the way) in front of the box so it stops it from moving forward, it wont move much side to side, and just push it back to the back seat.
Old Aug 15, 2002 | 10:32 PM
steveng's Avatar
steveng
use some metal taps. one side screwed on the box, the other screwed on the car metal. there's a name for the metal taps im talking about, but i forgot what it's called
Old Aug 15, 2002 | 10:49 PM
b00gers's Avatar
b00gers
theres a lot of way...if you dont mind it being ghetto, you can get real creative. ive used bungee cords before, and had no problems.
the way a box is designed also can determine if itll move a lot. something with a bigger base than a top will be less likely to move than something that is equal, both top and bottom.
also, a carpeted box will move less than a non-carpeted one, due to friction.
you can always bolt it to the car, but i dont like, too much of a hassle.
if you are building the box, give it a good base to stand on.
Old Aug 16, 2002 | 12:00 AM
A96's Avatar
A96
i currently have my single 10" box in my trunk with velcrow.
it use to work good but now it's starting to slide around.
Old Aug 16, 2002 | 05:32 AM
derf's Avatar
derf
Spec5
i put a piece of ply wood underneat the factory corrugated cardboard cuz that wouldn't hold shiiit.... i then put two locking hasps on the back of the box and then into the ply wood... locks it on.. doesn't moove a bit but does some rattle.. i don' trelaly mind the rattle though. i can still remove it for when i move a lotta stuff so my trunk is still useful
Old Aug 16, 2002 | 05:38 AM
Brad's Avatar
Brad
wooo nascar!
i just got some L brackets from home depot and screwed them into my plywood floor... kinda permanent tho.. takes a lil while to get em out if u need some space.
Old Aug 16, 2002 | 06:53 AM
acuradriva's Avatar
acuradriva
i built the box with the sub facing up. and the box is touching the back of the hatch then i have to slam the seat shut and that holds the other side of the box. it doesn't move anywhere.
Old Aug 16, 2002 | 07:02 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
if i was a smart theif i wouldn't worry about the lock but instead loosen the hinge with a screwdriver
Old Aug 16, 2002 | 10:23 AM
steveng's Avatar
steveng
:naughty:
