What do you think of this Memphis Amp?
I'm Shy :(
It's an ebay item. However I was just wondering what your thougts were? I have 2 10 inch subs that I believe are pushing 600 watts total. This amp will be pushing 1100 watts at one ohm and 1 channel. What do you think of this set up? I'll try and get pics of it once it's done. This will be going in a 03 Tacoma which has no back space for subs or anything. One of the seats had to be converted into the box where the subs will be. People will still be able to sit in that seat.
Here's the link to the amp: What year is this amp?
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
I'm Shy :(
Originally Posted by saga
If you're pushing 1100W into 600W speakers they'll rip like those cheap paper towels in Bounty commercials.
1 kW on a pair of subs that handle 600W will be fine if you use common sense. Post up what subs you want to use.
on a side note - what an idiot - it's a Capacitor - not a Capacitator..haha
broke college kid
Diamond Audio turns me on
Let's see what kind of subs and voice coil impedence setup he's talking about before we make the hasty assumption that this'll fry his subs. He says he thinks they're pushing 600W; doesn't mean that that's what they're capable of handling. Nor does it necessarily mean he'll wire them at 1ohm on the Memphis.
And even if it's a 1100W wired to feed the subs that handle 600W, you can always set the gains down. It's not set in stone that you HAVE TO turn the gains up. Like rcurley55 said, just use common sense and you'll be fine. I've run a 250W RMS sub in a temporary setup for months off a 1000W amp and it never blew cause I wasn't stupid enough to crank it up full blast - I just set it reasonably.
I'm Shy :(
Ok my subs are pretty much done and installed in my truck. The wattage if I'm correct is 500 watts each sub. And the amp is 1100 watts. It hits pretty damn good and hard however I need to change my speaker components on my doors and what not. That will come later on. I also need to get a new deck because my stock deck doesn't put out as much power as it should. It's only maybe putting out half of what it should be putting out. I'm thinking of adding a third sub just to cover the whole back seat area and get another amp.
If you want to push it as hard as you can all the time it's gonna kill them. With my work as a sound engineer working with rigs of 50k watts and such total power and dealing with professionals in the industry I have always been told to match RMS on speakers and AMPs. Gives the cleanest best sound while also not risking your speakers. Of course to each his own. I'm one to have my speakers not be pushed too hard than to have them being pushed to their limits constantly.
I'm Shy :(
I don't push it hard all the time. With my stock deck it doesn't give the full power to my subs it should. I'm working on getting a new deck in the next month or so. I'm also going to be changing my door speakers as well. My stock door speakers don't sound to bad but I'm going to change them anyways.
