Power cable wiring for 03 civic
anyone know a good place to run 2 awg power cables to the trunk. Is there a hole somewhere in the firewall. If not where is a good place to drill
always look for a factory grommet b4 drilling. especially drill on a civic will do more damage than good.
theres a grommet under the passenser side carpet. try that first!!!
man, 2 american wire guage huh? what are you running that needs so much currents to be pass by?
i just went to go check out the car the only grommet i see is near the center console is it that one that you are talking about? I dont think it can fit w/ all the other wires that are in there. Workign on security later.
ok finally decided to drill a hole on the driver side. There is a spot under the break master which has no wires. you gonna need a really long drilling bid. it drops right into the inside of your car right next to the kick panel so it is easy to run the cable
