Subwoofer Box Question.........
Old Jun 29, 2004 | 11:10 AM
93DelSolSi's Avatar
93DelSolSi
Default Subwoofer Box Question.........
My subwoofers are
Rec. Sealed Box Dims: 0.50 cu.ft.
Rec. Ported Box Dims: 1.15 cu.ft.
So that means i need a box thats .50 cu ft ?
If so i cant find one anywhere
please help, thanks
Old Jun 29, 2004 | 01:41 PM
93DelSolSi's Avatar
93DelSolSi
....up
..upup
upupup.
...up.
...up.
...up.
Old Jun 29, 2004 | 04:57 PM
99IntegraGS's Avatar
99IntegraGS
Originally Posted by 93DelSolSi
My subwoofers are...
Do you have more than one subwoofer?
.50 cu ft X # of subwoofers
2 subs would need a box that was 1 cu ft. This isn't a 1x1x1 box, it'll larger than these dimensions. Internal volume is not figured using the external measurements. A "1 cu ft box" also must be larger to account for the space displaced by the subwoofer magnets.
http://www.crutchfield.com/S-PCvv0Qw...&avf=N&search=
Old Jun 29, 2004 | 07:00 PM
93DelSolSi's Avatar
93DelSolSi
2 so, 1 cu ft then
Old Jun 29, 2004 | 07:37 PM
99IntegraGS
2 so, 1 cu ft then
Yes.
What are they, 10's or 12's?
Old Jun 29, 2004 | 07:55 PM
b00gers's Avatar
b00gers
https://www.honda-acura.net/forums/s...d.php?t=144847
you need a box that will hold 2 subs. i would suggest a box that has a divider that keeps the chambers of each sub separate. each chamber will need to hold ~.50cu ft after accounting for the space that the woofer structure takes up. which should be listed in your spec sheet for your sub.
btw, are you still planning on building your own?
Old Jun 29, 2004 | 08:06 PM
99IntegraGS
If he's not, this may be a suitable box.... as long as he loses those grills.
http://www.crutchfield.com/S-NHZe3bm...&avf=N&search=
Old Jun 30, 2004 | 07:49 AM
93DelSolSi's Avatar
93DelSolSi
2-10" i went to best buy, they have a nice on like that, with grills, and had 2 holes on the top, i dont know what those were for, but he said it was the best box they had for the 2-10" subs.
Old Jun 30, 2004 | 07:50 AM
93DelSolSi's Avatar
93DelSolSi
will that work with my 2-10" subs ?
Old Jun 30, 2004 | 09:04 AM
99IntegraGS
...and had 2 holes on the top, i dont know what those were for...
The two holes are ports.... they would change your enclosure size requirements dramatically.
My subwoofers are
Rec. Ported Box Dims: 1.15 cu.ft. (x2 subs)
You'd now need a box that's 2.30 cu.ft.
Yes.
