help me! What is REMOTE TURN ON aka POWER CONTROL, SYSTEM CONTROL, and REM?
Old Apr 27, 2004 | 08:20 PM
slammed_civic89's Avatar
slammed_civic89
:werd:
Default help me! What is REMOTE TURN ON aka POWER CONTROL, SYSTEM CONTROL, and REM?
What is it? And where does it go? Oh I have an 89 civic hatch. It's the only thing not hooked up and my amp and subs aren't working, and I think it's because of that. HELP ME PLEASE!!!
Old Apr 28, 2004 | 02:53 AM
flyromeo3's Avatar
flyromeo3
remote turn on is a wire from the radio ( aftermarket ) that hooks up to your amps.
Once you turn on the radio it sends a 12v signal to the amps to turn them on.
On Sony radios its a blue wire with a white line on it.
Old Apr 28, 2004 | 10:10 AM
b00gers's Avatar
b00gers
your aftermarket headunit has a remote turn on wire that goes to your amp. your subs isnt working because the amp isnt turned on. what headunit are you using? if you are using the OEM headunit, you can run a wire from the antenna to the remote turn on on the amp.
Old Apr 28, 2004 | 07:17 PM
slammed_civic89
:werd:
I figured that out. Now it works fine but I'm not getting much sound from it, I have it turned almost all the way up and everything is hooked up right. This is killing me. PLEASE HELP!
Old Apr 29, 2004 | 09:23 AM
mossman's Avatar
mossman
Mark
Explain what your system consists of and maybe I will be able to help.
