~*help*~
Old Mar 16, 2004 | 08:54 AM
96ackJfK's Avatar
96ackJfK
Default ~*help*~
ok look check it out, i have a 96 integra....i unhooked my power cable, and hooked it back up, the problem is that it set the anti theft, and i never got the codes(it is used) i even tried to go aftermarket and that wont even work, at first we thought it was the aftermarket cd player but it works in my cousins g2 integra, i know the serial number and vin number if anyone could please help it would be greatly appreciated...
Old Mar 16, 2004 | 10:20 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
please be more specific as to whats going on, what you're trying to do... etc.
Old Mar 16, 2004 | 01:07 PM
96ackJfK's Avatar
96ackJfK
ok, when i turn on the stock radio and its plugged in blah blah blah...it asks for a code...i tried to install an aftermarket cd player in hopes to bypass the anti theft b.s., but that did not work...i was wondering if there was any type of "reset" code or anything along those lines...maybe then i could get some radio action in my car, and hopefully use the aftermarket cd player....
Old Mar 16, 2004 | 05:55 PM
b00gers's Avatar
b00gers
search for a thread here, there was a guy that can get you the codes if you provide him with the numbers.
what car are you refering to?
Old Mar 17, 2004 | 12:56 AM
SumAccordGuy94
Older Honda Fanatic
the code only applies to the OEM radio. It has an internal security feature making it unusable without the code once power has been removed from it. It does not affect the cars wirring in any way. There is a possibility you have a blown fuse somewhere, or maybe a loose connection/wrong wire somewhere. There are a couple fuses that send power to the radio, so make sure you get them all.
