help plz
Old Mar 13, 2004 | 07:02 AM
ap716's Avatar
ap716
Default help plz
ok im going to install a aftermarket cd player for the first time in a 93 accord. im going to put in the alpine cdm 9801. the question is how do i connect the wires of the alpine cd player to the wires of the harness im going to connect to the other harness? oh yeah i dont want to solder the wires. also what accessories do i need to connect it?
Old Mar 13, 2004 | 03:47 PM
strychnine's Avatar
strychnine
i am legend
I'm not sure I quite get what you're asking but I'll try. You should be able to just match the wires up and crimp connect them (though soldering seems to be the better way to go). You can get connectors at lots of places, auto parts stores, walmart, radio shack. Just get some connectors and a crimp tool like this and you should be good.
Old Mar 14, 2004 | 10:33 AM
b00gers's Avatar
b00gers
there are a lot of different ways you can connect them. the best way is to solder then add some heat strink tubing over it.
and there are all sorts of connectors you can use. just make sure you get them really connected. go to your local car parts store and they should have a whole shelf full of them. and with some connecters you will need a crimp tool like strychnine suggested.
Old Mar 15, 2004 | 05:23 AM
ap716's Avatar
ap716
so do i put both the aftermarket wires and the harness wires then crip them?
Old Mar 15, 2004 | 07:32 AM
b00gers's Avatar
b00gers
these are butt connectors.
its basically a tube with a metal middle covered in plastic. what you do is strip off some of the insulation from the aftermarket wires and the harness wire, then stick them both into the tube. hold it steady, then lay down a couple good crimps in the metal. then tug on the wires to make sure they are good. you might want to practice on some spare wiring first.
you should end up with something like this...
Old Mar 15, 2004 | 09:48 AM
rcurley55's Avatar
rcurley55
www.installdr.com - do some research there - it should cover just about every headunit install question there is.
And remember, step one is to disconnect the friggen battery!!!
sivicdx
Jul 20, 2003 12:12 PM
96sedanR
92+ Civic/EL & Del Sol
39
Jul 13, 2003 10:11 PM
vincehk
Accord
4
Feb 9, 2003 01:19 PM
96sedanR
Showroom
Jan 16, 2003 09:53 PM
RSXCLUBR
NSX
3
Oct 18, 2002 12:06 PM
