car audio gurus enter!
Old Mar 3, 2004 | 05:12 AM
BullFrogger's Avatar
BullFrogger
Banned
Default car audio gurus enter!
ok first Q: are infinity 652i 6 1/2 speakers any good? would they be alot better with an amp? what type of amp. thansk!
Old Mar 3, 2004 | 06:08 AM
Bl@ck's Avatar
Bl@ck
Sinner
in short.. yes.. infinity speakers are nice, but not the beast out there by any means. with woofer cones, they'll probably sound a lot better amplified, but you can probably get away with running them off of your HU with no problems as long as they're on a crossover.
Old Mar 3, 2004 | 06:14 AM
amp should make pretty much anything sound better
Old Mar 3, 2004 | 06:21 AM
redgoober4life's Avatar
redgoober4life
I eat plastic.
If I was a mod I'd move this to the car audio section...
Alas I can only use my psychic powers for so much.
Old Mar 3, 2004 | 06:54 AM
yeh.. more people will read it here though
Old Mar 3, 2004 | 08:26 AM
BullFrogger
Banned
crossover?
Old Mar 3, 2004 | 08:46 AM
b00gers's Avatar
b00gers
yes, an external amp will be much better than the amp inside of a headunit. a crossover limits certain freqencies to be played by the woofer and tweeter.
Old Mar 3, 2004 | 10:56 AM
Bl@ck's Avatar
Bl@ck
Sinner
Originally Posted by BullFrogger
crossover?
a filter that blocks frequency ranges so that you don't get bass buzzing in tweeters, or woofers trying to reproduce high frequencies.
Old Mar 3, 2004 | 12:30 PM
ikarus's Avatar
ikarus
are crossovers hardware parts? or are they internal within the amp? wtf are they and how are they setup?
Old Mar 3, 2004 | 01:33 PM
Bl@ck's Avatar
Bl@ck
Sinner
yes to both.. they are hardware and most new amps have them built in with a switch that allows you to switch between low pass/mid pass/high pass.
a crossover is a frequency filter that allows a desirable frequency range to be passed to the speakers.
for instance, if you have a tweeter, you don't want low frequencies going to it because it'll buzz and sound like ass. that's where the crossover comes into play. it filters out the low frequency range and allows the high, desirable frequency range to pass to the speakers.
