is this amp decent?
Old Jan 22, 2004 | 09:57 AM
Max Power's Avatar
Max Power
Buff Member
Default is this amp decent?
i currently run only a pioneer 6400 in my civic . . . everythign else stock and
my friend just gave me this jensen xa250
i was wondering if/how i should use it or not. since i aready mounted it in the back, i was going to buy some pioneer 6x9s and put the amp on those, then later get some 6.5's in the front. what would you guys do?
-mosfet powersupply
-2 channels
-RMS Power Per Channel @ 4ohm 50 x 2
-RMS Power Per Channel @ 2ohm 75 x 2
-RMS Power Bridged @ 4 ohm 150 x 1
Selectable crossover (High pass/low pass/full range)
Variable high pass crossover (40-400Hz)
Variable low pass crossover (40-400Hz)
12dB/Octave crossover slope
12dB Variable bass boost @ 45Hz
High level inputs
Input level controls
Pass through RCA outputs
Extruded aluminum heatsink
Old Jan 22, 2004 | 10:10 AM
rcurley55's Avatar
rcurley55
it's decent, but Jensen isn't the best thing out there. Lately they have been making rated power. It would probably be a good amp to add to a small subwoofer to add a bit of bass to a system...
Old Jan 22, 2004 | 01:12 PM
Max Power's Avatar
Max Power
Buff Member
what is rated power?
and why do you say is it preferable to power a sub rather than 2 loudspeakers?
Old Jan 22, 2004 | 01:17 PM
rcurley55's Avatar
rcurley55
Perhaps I wasn't clear....
Rated power is what the manufacturer claims the amplifier will produce...
Measured power is well....measured...it's what the amp will actually do.
Cheap, flea market brands typically over rate their amplifiers (sometimes by a factor of 2 or more) to make them look better then they are. I've seen plenty of "2000W" Legacy amps that weigh 3 lbs and have a 40A fuse on the side of them.
Most of the good amplifier manufacturers under promise and over deliver - meaning a 50W amp really turns out to be a 75W amp. The old SoundStream and Rockford Fosgate amps were very well known for exhibiting this - that's why people call them under-rated.
As for it being good for one application or the other....it will work fine on any speaker, but it could be a nice addition to your particular setup to get a single 10" subwoofer perhaps to augment the current cabin speakers you have. It was just a suggestion. The amp is certainly capable to power those 6x9's or the front speakers!
Good luck!
Old Jan 22, 2004 | 06:10 PM
Max Power's Avatar
Max Power
Buff Member
thanks for the help man
Old Jan 23, 2004 | 09:15 AM
honura's Avatar
honura
Seni
Basicly its a shitty amp but it will do the job ! I rather hook that up to my highs if anything ! But yeah get the real deal it will be better all around !
Old Feb 12, 2004 | 07:03 AM
mossman's Avatar
mossman
Mark
-mosfet powersupply
-2 channels
High level inputs
Wouldn't use it for a sub. You will just want the bass louder and louder. It will be great for some 6x9's etc. Most amps display the total system power of the amp. They just add up the output of each channel and post it on the amp to make it seem better than it really is. What you need to look at is the RMS/Continuous Power of each channel or the combination of channels you plan to use. This is the power that the amp will always provide at the least. Do not buy an amp according to its Peak power. Peak is the max that the amp can provide. Peak power = 1.41*RMS.
