need to put a radio in 94 v tech 2.2l but some cut out the harness
Old Dec 11, 2003 | 08:13 AM
bigtwan25's Avatar
bigtwan25
Default need to put a radio in 94 v tech 2.2l but some cut out the harness
i was wondering if anyone had factory diagram or could just tell me what the wire colors mine and if possible send me a diagram every thing in the car is all power !
Old Dec 11, 2003 | 08:57 AM
Surfacing171's Avatar
Surfacing171
cb7 fanatic
Default Re: need to put a radio in 94 v tech 2.2l but some cut out the harness
The harness that came w/ the radio will match up to the stock colors. For instance, you'll have green wires and red wires, they just might be different shades, but still do the same thing. So you saying that someone cut your factory harness? If you have any trouble installing your radio, give crutchfield a call and order a installation kit from them. They give detailed instructions about EVERYTHING and they will offer tech support too. Good Luck!
And for future reference, when posting in the audio section, it is not necessary to tell us what kind of engine you have.
Old Dec 11, 2003 | 09:26 AM
bigtwan25's Avatar
bigtwan25
yes somone cut the factory harness so i was just tring to figure it out
Old Dec 11, 2003 | 09:41 AM
b_dyche's Avatar
b_dyche
owned by a 9 car pile-up
I did that to my '86 Corolla, then lost the factory piece... :doh:
Take it to a car stereo shop and have them put a new factory plug on... it should cost < $20, parts & labor. Then do yourself a favour and get an installation kit that plugs right into the factory harness, that way you don't have a shit ton of wires to mess with and less of a chance of frying something...
Old Dec 11, 2003 | 10:12 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
Default Re: Re: need to put a radio in 94 v tech 2.2l but some cut out the harness
Not even close...
They are as follows...
Left Front Spkr (+) Blue w/ Green Stripe
Right Front Spkr (+) Red w/ Green Stripe
Left Front Spkr (-) Gray w/ Black Stripe
Right Front Spkr (-) Brown w/ Black Stripe
Right Rear Spkr (+) Red w/ Yellow Stripe
Left Rear Spkr (+) Blue w/ Yellow Stripe
Right Rear Spkr (-) Brown w/ White Stripe
Left Rear Spkr (-) Gray w/ White Stripe
Ground Wire Black
Power Antenna Trigger Brown w/ White Stripe
+12 Volt Battery Wire White w/ Yellow or Blue Stripe
+12 Volt Ignition Wire Yellow w/ Red Stripe
Old Dec 11, 2003 | 10:55 AM
Surfacing171
cb7 fanatic
Default Re: Re: Re: need to put a radio in 94 v tech 2.2l but some cut out the harness
Originally posted by SumAccordGuy94
Not even close...
Ground Wire Black
I didn't know all the colors, I was just tyring to give him some guildlines to go by. I hate you for knowing all those :fawk:
Old Dec 11, 2003 | 09:22 PM
bigtwan25's Avatar
bigtwan25
good lookin u guys are great like whoa
