Weird car audio problem
Old Nov 17, 2003 | 10:48 PM
Shore 96 Teg's Avatar
Shore 96 Teg
I miss my 93 VTEC Lude :(
Default Weird car audio problem
Sorry if this is the wrong forum but i need some integra owners with systems to help me out on this one. When I pause the CD player i get static and noise playing through my rear speakers. Also when i give it gas they whistle. The higher the revs, the higher pitch. Kinda sounds like a spooling sound. Its also inconsistent. Sometimes its there and sometimes it isnt. I have my power and RCA's run seperately. I have a SOLID ground in the trunk. Could it be how I have the power like run in the engine bay? Also this is a recent development, I never noticed it a month ago. Anyone have any suggestions?
Old Nov 17, 2003 | 11:23 PM
ragerized's Avatar
ragerized
dc4 ownerages
sounds like a ground problem to me...could be your radio ground?
Old Nov 19, 2003 | 03:04 AM
Bmpn's Avatar
Bmpn
Audiophile
two things... sounds first off like alternator whine. alot of cars have it, and its a PITA...
umm recheck your ground, and is your ground on paint, or did you scrape/sandpaper/grind the surface so it is 150% metallic and has no painted area?
good luck.
Old Nov 19, 2003 | 11:16 AM
Shore 96 Teg
yes i did scrape the paint off the ground....how can i fix the wine?
Shore 96 Teg
yes i did scrape the paint off the ground....how can i fix the whine?
Old Nov 21, 2003 | 01:08 AM
bdm162003's Avatar
bdm162003
hey dude just tell ur friends u got a turbo... na try changing ur ground location it might be a ground loop also the noise is prob from ur rca cable if there near ur power cable or u can get alot of noise from wiring ur remote wire directly from the fuse box or near it
Old Nov 22, 2003 | 09:43 AM
YeaItsAFourDoor's Avatar
YeaItsAFourDoor
..::-Free your mind-::..
Sounds like alt. whine ...just run the RCA's on the other side of the power wire.
Old Nov 22, 2003 | 06:04 PM
Surfacing171's Avatar
Surfacing171
cb7 fanatic
:thumbup:
Old Nov 22, 2003 | 10:57 PM
Shore 96 Teg
power wire is on the driver side and the RCAs are on the passenger side...sorry havent checked in the while. Also when i turn the car on and off the sub pops. i have the remote wire hooked into the fuse panel next to the steering column....could that be causing it?
Old Nov 23, 2003 | 08:50 AM
Bmpn's Avatar
Bmpn
Audiophile
possibly. the remote wire should be hooked to the blue wire on the back of the deck...
