4 ch amp install wiring
Old Oct 31, 2003 | 07:57 AM
WHITEPEARL ACC's Avatar
WHITEPEARL ACC
Default 4 ch amp install wiring
i just wanted to know the speaker wires, do i just connect to the radio harness spkr wires...or do i fully cut it off at harness and connect only from amp to the internal spkrs??
Old Oct 31, 2003 | 12:36 PM
smokedogg's Avatar
smokedogg
I wouldn't connect an amp to the stock speaker wires through the harness, the speaker wires in the harness aren't exactly made for amps and higher powered speakers. Plus, if you have high quality speaker wire, you'll be defeating the purpose of it by attaching it to factory wires. I have my speaker wires running directly from my amp to each of the speakers.
Old Oct 31, 2003 | 01:24 PM
WHITEPEARL ACC
If i do that, i will have to reroute all the wires....that is going to be long....since i see ppl who have mosfet 50w x 4 receivers using stock wires as well...since from harness...
Old Oct 31, 2003 | 06:54 PM
rcurley55's Avatar
rcurley55
No headunit actually puts out 200W of full bandwidth power....
Do not cut the factory harness connector off of your car.
You can run speaker wire from the amp to the harness adaptor (the part that goes between your deck and your car) and run it that way.
