Metalic Tint Messes Up Navigation System
I have an 03 Accord with Nav. Just tinted the windows and the Nav is going crazy. The signal is really weak and the indicated position of the car is wrong most of the time.
Anyone ran into this problem? Any remedies?
I appreciate all inputs.
Thanks,
Tim
Thanks,
Tim
It worked fine before the windows were tinted. I remember reading somewhere that metalic tint may interfere with the GPS signal.
Just hoping that someone in the forum has experienced the problem and share some ideas.
I like the windows tinted, and don't want to remove the tint.
Look in the nav manual and find the location of the GPS sensor / antenna .. it could be located near one of your windows and if it's trying to get a reading through the glass -- you are right the tint is probably the problem. Also doesn't the Honda GPS rely on a compass as well? I believe so because the nav system will still function without a GPS signal as it knows the relative speed and heading of your car (as long as the starting point is known) .. perhaps the metallic tint is messing with the internal compass somehow. Just some thoughts .. --Brian
the metalic tint is just that... it has a metal film in it. The GPS antenna is in the rear deck of the car, and needs the whole rear window to recieve its signal. There is no compass, as GPS does not need a compass. You're gonna need to get normal tint to allow your navi to work.
Metalic tint is ugly and illegal anyway.
Yes, but how would the nav system still continue to function when there is no GPS signal, as Honda's does. My guess would be the system would need speed sensors and an internal compass to continue to operate this way. And it's remarkably accurate without a GPS signal (ie going through long tunnels, etc) ..
Here is my observation...
If there is a destination selected, the software will adjust the location of the car with the travel path even if the GPS signal is a bit mixed up. The software tries to maintain the location of the car based on the mapped streets. I had no problem going from San Diego to LA on Sunday.
Without the selected destination and weak signal, everything is pretty much messed up. Tried not to select the destination going back, and it was all screwed up.
I will take the car in to have the rear window retinted with non-metalicized tint. I was no "No charge".
