Weird noise at low RPM's (5th gen)
My fifth gen ex manual, makes this funny sound in first and second gear when the r's fall below about 2k...it sounds like a motor mount being brokemn or somthing, like a really bad vibration, its pretty loud, i can fix it by givin it a little gas, but its kind of anoying in trafiic when theres no room to take the r's any higher than they are.
I know its not a motor mount though becasue i had the 125k service done a while ago, and they must have checked them because i know they had to replace one...
Is this just a normal noise? It also does it when cold starting, it will idle up to around 2k, and about 1 second after scarting it will idle down, right around that point, amke the weird noise, idle down past that point and stop making the noise.
The noise occurs in nuetral, first, and second, right about 1800 RPM...
Fight Rice
its in the 94-95 accords. its a normal problem. it has to do with the exhaust piping and the connections. for some reason, at about 1800 rpms, there is a vibration. there is nothing to worry about. it goes away if you replace the exhaust with a catback exhaust.
The heatshield around your cat converter is loose.
Infamous 1800rpm buzz, I have it as well.
You can find a way to tighten it up, or buy a $70 buzz kit that Honda sells to fix it (Dont last too long), or just rip it off but if your lowered dont park on high grass.....
Honda knows about this and even makes a fix kit (temp) but wont recall it to fix it.....
http://www.secureleadercom.com/exsto...ept=306&page=2
(Look at the 94-97 4cyl EXHAUST ANTI-RATTLE KIT)
Mr Clutch
Originally posted by pirate252
Alright, thanks, i just wanted to make sure it wasnt a motor mount after i gave the stupid dealer all that money to fix it
It turned out to be a bad downpipe. The inside of the pipe was shattered and that was the cause for the rattle at low rpm's
Yeah i know, i hate it cuz all my freinds give me this weird look and ask me wtf is wrong with my car... and i can hear it over my music, which is defianatly a bad thing
Originally posted by DSi
did you DIY?
details! details!:thumbup:
did you DIY?
