Rear Brake Pad Replacement
Old Sep 30, 2003 | 11:49 PM
HrZnAccRd's Avatar
HrZnAccRd
Default Rear Brake Pad Replacement
i've got a 1994 accord, and i recently tried to replace my rear brake pads. I took out the two caliper bolts, and the caliper is supposed to "pull right off" so says the Hayes manual. But as hard as i try to pull, it won't come off.
Any ideas or links to a rear brake pad replacement? It would be much appreciated!!
thanks.
Old Oct 1, 2003 | 04:08 AM
lingerbw's Avatar
lingerbw
Hit it with a hammer :dunno: but I have seen mechanics whack calipers with a small sledge hammer after removing the caliper bolts, and the caliper just pops right off. However, I have never done it.
Someone who has done this have some advice for him??
Old Oct 1, 2003 | 07:47 AM
JimBlake's Avatar
JimBlake
Release the handbrake.
OK, seriously... sometimes I have to push & pull a bit, and use a small crowbar. Unhook the handbrake cable to give that a bit more slack.
Old Oct 1, 2003 | 02:43 PM
greaselightning's Avatar
greaselightning
yeah, i just did mine on my '99....I had the e-brake on like an idiot for a bit, and was like, why won't this come off?? Once I released that, then it took a bit of shimmy-ing to get the calipers off. We used a small crow bar and a hammer mallet to whack it off and eventually it worked off.
Old Oct 1, 2003 | 03:14 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
I'd recommend a nice platic or rubber headed mallet. You can generally find soft head mallets at the tool store. This helps prevent chipping or cracking metal off some of the cast parts.
Old Oct 1, 2003 | 09:31 PM
HrZnAccRd's Avatar
HrZnAccRd
thanks for the tips guys. I'll try that tomorrow morning and see if it works. ...e-brake... hahaha... j/k. i had mine down.
thanks again.
