Exhaust System.....
Old Sep 20, 2003 | 07:31 AM
MIKSFOk's Avatar
MIKSFOk
Default Exhaust System.....
Sup guys. Little curious...
I got my exhaust done couple months ago.
When I got mine done, engine check light came on.
I asked them if it was ok and their response was ok.
But When I got my oil change, the man work there said " Better change that before it blow off " People who got exhaust system done, do you guys have engine light on??
Am I in danger?
Should I just take system out and use muffler instead?
Please write back.
Old Sep 20, 2003 | 12:35 PM
uclaccord's Avatar
uclaccord
i didn't have any problems...did you do the exhaust install?...is it a full catback that u just bolted on?...better ask the guy that did the oil change what he's talkin bout...what would blow off and how much to fix
Old Sep 21, 2003 | 04:17 AM
Bl@ck's Avatar
Bl@ck
Sinner
did you try resetting the ECU? sometimes a change such as new exhaust, etc.. will cause the diags to throw a trouble code. pull the ECU fuse for about 5 minutes and put it back in. crank the car and let it idle for about 10 minutes with everything else turned off.
Old Sep 21, 2003 | 07:42 AM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
Default Re: Exhaust System.....
Am I in danger?
Please write back.
I've had my exhaust for like 3-4 months now, only time I threw a code was after getting my clutch installed when they didn't put my o2 sensor all the way back in and it fell out.
Other than that, no problem. Just curious, what the hell is the oil change dude talking about when he said "better change that before it blows off."? What a tool, that's why he's doing oil changes and not engine swaps:screwy:
