2000 Accord Coupe<~~~~In need of camber kit
I have a 2000 Accord Ex Coupe 5 Speed with Eibach Pro-kit springs and I went to sears today and had them install some tires I bought off of tiretrack.com (bridgestones). Well I had them do mounting and balancing and also an alignment. They showed me the paper and said my rear left camber was out of camber manufactures specifications. So now I guess I have to purchase a camber kit or else am going to go thru alot of tires on that side, well here is a pix of the results that they gave me. My questions is that the only thing that is out of whack? Or anything else? Also what is a good brand for a camber kit? Thank you all for your responses.
THE RED 6th GEN Coupe
Go back to Tirerack and order the Eibach rear camber kit. This will fix the problem. What a waste, you had springs installed without the camber kit. Now you have to pay twice for a quick install.
At least I have an excuse the camber kit did not yet exist when I purchased my springs. :naughty:
Originally posted by Weiman
i heard u can ghetto rig the back tires with some washers...only the front is in real need of cambers...(front cant be fixed by washers.
About the rear. Honestly, you can probably live just fine with -1.4 degrees. How low are you dropped? That's only .4 out of spec.
But if you really want the most life out of your tires, camber kit will help.
