Knocking = Potential Engine Problem?
Old Sep 17, 2003 | 06:31 PM
MrMJPEG's Avatar
MrMJPEG
Originally posted by AccordManiac
I would say.. time for valve adjustment..
Ugh. After only a year and a half?
But, if I'm not mistaken, it is important for the valves to seat long enough to disipate their heat. So keeping them adjusted is probably important.
Old Sep 17, 2003 | 07:40 PM
Big Chaze's Avatar
Big Chaze
Mr Clutch
Default Re: Knocking = Potential Engine Problem?
Originally posted by MrMJPEG
I'm hoping those of you who know something might be able to diagnose this for me.
When my '94 LX Wagon's engine is around 1200 RPM there's a knocking sound under the rocker panel. When I'm holding the throttle open I can feel the engine shake slightly, like it is missing a bit. It goes away as long as it isn't in a narrow band around 1200 to 1500 RPM.
Without knowing any better, it seems like the exaust vavle(s) on a cylinder are floating at this RPM and the knocking I'm hearing is exhaust. But if this is the case, why do HIGHER RPMs make the problem go away?
Valves were adjusted and timing belt replaced a year and a half ago at 80,000 miles by a Honda dealer ($$$). Gas mileage is fine and unchanged, car accelerates fine and has 120,000 miles. Exhaust is noisy under a load, but there seems to be no single source for the exaust sound other than the area around the exhaust manifold.
This might be pertinent: I have a pretty bad pinging problem that I'm going to attempt to tackle by getting a tuneup. When the engine is warm I sometimes get really bad pinging under a light load. Downshifting the automatic usually helps. I can't get the 3 distributor bolts loosened to try to retard the timing. I'd rather not have to resort to a higher octane fuel.
Thanks in advance!
The sound you're hearing is coming from the main bearing. It almost sounds like your engine is snoring.
It's not your valves, they make a different noise than what you're hearing. Try not to worry too much, just change your oil regularly and try to do tune ups before thier time.
Old Sep 17, 2003 | 08:13 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
:driving:
Old Sep 18, 2003 | 08:25 AM
MrMJPEG's Avatar
MrMJPEG
Default Re: Re: Knocking = Potential Engine Problem?
Thanks! I sort of feel better. Although, having my main bearing causing the engine to stutter a bit and snore isn't all that comforting!
But I'll keep on the oil changes and make sure it is tuned up. Thanks!
Old Sep 18, 2003 | 05:28 PM
ItsaHonda's Avatar
ItsaHonda
Now that I paid attention, I do hear my engine knocking between 1800-2,000 rpms while driving, and it does sound discomforting. I heard it while driving home from work, so I parked my car in the driveway, lifted the hood and reved the engine via throttle cable, sure enough, at 1800-2,000 rpms the knocking came in... it sounds like a grinding/knocking, and I can actually feel the engine vibrate a bit more when it comes in. From inside the car, holding the engine at a steady 2,000 rpms, it sounds like Im grinding coffee. If I rev higher, it tends to fade out. I dont know what I could have done to cause this sound to appear. The engine has close to 100,000 miles, mostly highway, and all run on Valvoline synthetic oil.
Old Sep 18, 2003 | 06:44 PM
Big Chaze's Avatar
Big Chaze
Mr Clutch
Yup, same here.
I dont think I heard it on the car when I first brought it. I hear it most right before 2nd gear kicks in.
My car has about 149 k on the odo. I put about 50k in 3 years, all highway.
Old Sep 18, 2003 | 07:17 PM
AccordManiac's Avatar
AccordManiac
Korean Member
Since I bought my car. last Feb..
I do have same problem as you guys.
My mechanic says.. I don't need valve Adjustment..
but I am thinking about getting it..
Old Sep 18, 2003 | 09:59 PM
lowelcam96's Avatar
lowelcam96
Have your EGR system checked.
passage could be clogged or partially clogged. A non-working EGR system does cause knocking sounds.
Old Sep 19, 2003 | 10:24 AM
Big Chaze's Avatar
Big Chaze
Mr Clutch
Wouldnt the engine throw a code then??
Old Sep 19, 2003 | 05:26 PM
lowelcam96's Avatar
lowelcam96
not if it's partially clogged
