5th gen door panel
Old Sep 13, 2003 | 10:07 PM
Matt86's Avatar
Matt86
vtec ownz j00
Default 5th gen door panel
I was trying to remove my pasenger side door panel in my 5th gen today and i got off all the screws and clips but the door was being held on still by something towards the top about 5 inches behind where the mirror is on the outside of the car. There aren't any more clips are there? Also, when removing the panel do i feed the door handle through the hole in the panel or do i completely disconnect that? Thanks
Old Sep 13, 2003 | 10:12 PM
aero3685's Avatar
aero3685
I am going off of a 4th gens door panels, but they should be the same. You are going to have to take off the handle(a screw in it, and slide forward, and disconnect) and the armrest thing(just one screw) then just make sure you have all the tabs, and you pull the bottom out, and slide it up. should come off easily.
Old Sep 15, 2003 | 12:36 AM
strykernyc's Avatar
strykernyc
quick advise be gentle on the inner handle especially if it has never been remove before, i broke mine since it had never been remove still had plastic and all that n the door now getting it today i pay $25 for it. thats sucks.
Old Sep 15, 2003 | 01:09 AM
jsinger's Avatar
jsinger
IH8S810
I'm assuming it's the front door. You have to remove that little black triangle on the inside that's behind the outside side mirror. You should then be able to lift up and pull the door panel off. There is also a small tab that pops out near the top left corner of the door panel just under the black triangle I was talking about before... if this doesn't help... i'll take some photos for you. Let me know
Old Sep 15, 2003 | 05:06 AM
Matt86's Avatar
Matt86
vtec ownz j00
I got it... I didn't take out that triangle though and it made it a bish to put back on though. Thanks for all the help
