Help annoying noise
Old Sep 12, 2003 | 12:52 PM
INFERNO1423's Avatar
INFERNO1423
Default Help annoying noise
I just raised my car back to stock, but now it is making a clanching noise in the back as if someone is tapping under my car. I only does it when I am driving slow and driving over little bumps and flaws in the road. I know it isn't the shocks or springs because when I go over a speed bump they don't make any noise. Not sure what it is, I jacked up the car and tight all the nuts and bolts in the rear. So i give up trying to figure it out. Don't feel like taking it to a shop.
Thanks!
Old Sep 12, 2003 | 02:30 PM
Illicit Accord's Avatar
Illicit Accord
hmmm what you might want to do is have some one drive it slowly and over flaws in the road, while you're walking behind it or aside of it looking and listening to what it could be. that could be a way to diagnose it. get back to me if that helps
Old Sep 13, 2003 | 12:51 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
check your rear sway bar the bolts might be loose. If they are not check your (rear) Control arms the bushing might be warnout or damaged.
*INFERNO1423
where in S. Cal you from maybe I can help.:thumbup:
Old Sep 14, 2003 | 02:04 PM
INFERNO1423
i use to live in Simi Valley, just moved to the lancaster. Don't know really anyone in S.cali.
I will check out my sway bars and control arms on monday at my in-laws.
Old Feb 9, 2004 | 01:04 PM
TurboEX's Avatar
TurboEX
Check the lug nuts on the rear wheels, If it's makeing a clicking noise or something similar it could be 1 or more loose lug nuts.
Old Feb 9, 2004 | 06:31 PM
AccordCoup94's Avatar
AccordCoup94
i have an annoying niose too.. its called my girlfriend :kiss:
Old Feb 10, 2004 | 07:51 AM
phat99accord's Avatar
phat99accord
BMW Tech
when did u change back to stock. If its within the first few days then it might be the springs settling properly.
Old Feb 10, 2004 | 03:04 PM
INFERNO1423
No I raised it up a few months ago and it still makes the same noise. It kinda sounds like an exhaust pipe under the car hitting on something. It is so freakin annoying it drives me nuts. Still can't figure it out. I think my rear bushing are worn out or something.
