Door handle??
Old Sep 11, 2003 | 06:48 PM
Matt86's Avatar
Matt86
vtec ownz j00
Default Door handle??
Today i tried taking the door pannel off on my accord so i could put in new speakers. THe only problem is i couldn't figure out how to completely take out the door handle. I unplugged the two wiring harnesses but i can't figure out how to get the wire thing on the other side off. Any help is greatly appreciated. Thanks
Old Sep 12, 2003 | 05:40 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
Im assuming you mean the metal rod attached to the actual handle to open the door...
there is a small plastic clip where the rod meets the handle... you have to un-clip it from the rod with a slotted screwdriver... it will turn away from the rod, then the rod will pull up and out of a hole in the handle.
