Removing door panel for 95 accord
Old Sep 7, 2003 | 01:02 AM
Quanger's Avatar
Quanger
Default Removing door panel for 95 accord
the power windows are struggling to get up. i wanna remove the panels on the door and give the gear for the power window some good grease and lubrication but im not sure how to remove those panels.
is there a technique on how to do it? the last thing i wanna do is pull it out breaking a whole buncha clips cuasing the panel to be loose and everything.
the windows coming up slowing isnt because the motor is about to die is it? if it is im gonna have to replace 4 power window motors and thats gonna be real fun
Old Sep 7, 2003 | 01:18 AM
JJJ784's Avatar
JJJ784
No Soup For You!
quite simple. remove screws, plastic retainers, then pop it out of the clips starting from bottom outside towards the hinge, then lift up slowly. also watch out for the door latch that you need to undo. after you do one, it'll be cake with the other. more clips on the drivers than the passenger.
