Starting problems, need help...
Old Aug 31, 2003 | 11:27 PM
KiDFuZioN's Avatar
KiDFuZioN
Default Starting problems, need help...
For starters I have a 1998 Accord Coupe 4 cyl. The problem is that the car will start up but then all of a sudden just die out. The RPM guage will go up when it starts up like it normally would and then drop down to 0 and shuts the car off. I have to press on the gas to get the car to acutally stay on. I don't know what the problem is, I haven't done anything new to it besides installing coilovers and a new strut. I can't seem to figure out what the problem is so I need all your help. Thanks in advance
Old Sep 1, 2003 | 01:53 AM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
sounds like a fuel problem, Possible bad main relay? check the basic three( fuel, spark,compression)
Old Sep 1, 2003 | 06:52 AM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
there was a recall on the 6th gen ignitions, did you get that work done? Could be part of your problem:dunno: Couldn't hurt even if it's not related.
Old Sep 1, 2003 | 08:44 AM
KiDFuZioN's Avatar
KiDFuZioN
Where did you see this recall at? I thought the recall was for 5th gen not 6th.
Old Sep 7, 2003 | 11:37 PM
Weiman's Avatar
Weiman
I had the exact same problem with my 94 accord. it would start up strong..if u keep key turned it stayed on right when u let go it goes to 0 right? check Ignition Switch. cost u bout 60-70 bucks.
Old Sep 7, 2003 | 11:41 PM
Archon810's Avatar
Archon810
had the exact same problem with my jetta, started happening more and more often, so i sold it asap and got a Honda was too tired and broke from all the problems it gave me...
Old Sep 8, 2003 | 09:12 AM
KiDFuZioN's Avatar
KiDFuZioN
I had Honda replace the ignition switch already and it still gives me the same problem. What else should I check before I take it in to have them throughly check it.
Old Sep 8, 2003 | 09:44 AM
Weiman's Avatar
Weiman
ummm, im taking a wild guess but try chainging the fuel filter? maybe its clogged and not enough gas is going to your engine. Do you smell gas when you rev the engine to keep it started?
Old Sep 8, 2003 | 04:28 PM
KiDFuZioN's Avatar
KiDFuZioN
Am I supposed to smell gas becasue I don't. Isn't the fuel filter supposed to last a life time? That's what people said on this forum.
Old Sep 8, 2003 | 05:21 PM
Weiman's Avatar
Weiman
not really. you should change it every 30,000 miles or so. you can do it yourself but its dangerous. you can prolly get it done at a shop for about 50. just curious how many miles u have? this is just a guess tho, but i would try it.
