Converting Power Windows To Manual
Old Aug 27, 2003 | 12:54 PM
cac's Avatar
cac
Default Converting Power Windows To Manual
Can it be done?
91 Accord EX 2 Door
That's power to manual because I don't want to pay the money to repair the parts.
Old Aug 27, 2003 | 01:03 PM
whoaitslen2's Avatar
whoaitslen2
hermit
yes it can be done.. just replace all the power parts with manual.. or swap doors with manual doors.. and then realize in the end that it would of been cheaper to just repair/replace the parts that are broken
Old Aug 27, 2003 | 02:00 PM
93accord4door's Avatar
93accord4door
upgraded to 97 ;]
lol yup thats true
Old Aug 27, 2003 | 02:48 PM
kaliraver69's Avatar
kaliraver69
Just replace the parts man.
Old Aug 27, 2003 | 02:58 PM
jfiedler's Avatar
jfiedler
Junior Member w/Fries
swap = pointless.
just do it right!
Old Aug 27, 2003 | 03:03 PM
92lx
Guest
Posts: n/a
ya, do it right, and besides, manual ones suck.
It's expensive I know, but seriously... just get it done and foot the bill.
Old Aug 27, 2003 | 03:49 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Default Re: Converting Power Windows To Manual
Originally posted by cac
Can it be done?
91 Accord EX 2 Door
Your not serious are you?
It would be way cheaper to just fix the problem on the power than convert to manual windows.
Conversion:
Rails
Crank assembly
Door panels
Installation
Probably some hidden costs as well
Repair:
A little wiring
Maybe just a switch or a fuse
Figure it out cac it seems worthless.
Old Aug 27, 2003 | 03:57 PM
detroitrice's Avatar
detroitrice
Go buy a cheap ass motor from a junkyard, I had to fix that same thing before and it was like $20 total to fix myself, but if you go manual, that's just retarded, that's a lot of work and there's no real reason to do it unless your whole door is just ****ed and nothing can operate unless you replace the door, then you could just convert, but if your door is that ****ed in the first place, then you probably won't even be able to make the manual dooors work either.
Old Aug 27, 2003 | 06:37 PM
AccordManiac's Avatar
AccordManiac
Korean Member
Replace the parts...... it will be more cheaper and parts are easily found.... try ebay for aftermarket / used parts.. or www.hondaautomotiveparts.com for Genuine OEM Honda Parts..
