Gas Pedal/ cable questions....
Old Aug 22, 2003 | 10:58 PM
Samson's Avatar
Samson
chris is the devil
Default Gas Pedal/ cable questions....
Why is it that if i press the gas and revv the engine, and let go of the pedal and let the RPMS fall by themselves..... that if i pull back on the pedal with my foot, the RPMS drop lower? Like the RPMS stay high(er) unless i pull back manually on the pedal with my shoe? Is this normal?
Go try it and see if your cars do the same thing.
Old Aug 22, 2003 | 11:04 PM
A_D's Avatar
A_D
Reset?
probably because you pull the throttle body cable more than it usually goes, or you pull it faster and it does this
Old Aug 22, 2003 | 11:14 PM
Samson's Avatar
Samson
chris is the devil
but sometimes the throttle will drop all the way down when letting it fall on its own, to the point that when i do pull it back, its already to the lowest point... so i dunno what keeps it up. Because if im adjusting the throttle, should i do it with the pedal pulled back or when it falls on its own?
Old Aug 22, 2003 | 11:24 PM
A_D's Avatar
A_D
Reset?
i dunno
i'm confused
